							| Display Name |
							Enter the name of the APN connection as seen by the Windows Connection Manager. |
							| Access Point Name (APN) |
							Enter the name or web address of the access point provided by your wireless carrier. |
							| Access Point Type |
							Select the access point type. |
							| Roaming |
							Specify whether the connection should be activated when the device is roaming. |
							| SIM Card ICCD |
							Specify the SIM Integrated Circuit Card ID (ICCID) that services this connection. Use this option with dual-SIM card devices to determine which SIM card will be used for the APN connection. |
							| Enable Proxy |
							Select this option the enable the use of an HTTP proxy. |
							| Hostname |
							Enter the name and port number of the proxy server. |
							| Bypass Local |
							Select this option to enable the proxy to be bypassed when local hosts are accessed by the device. |
							| Exception List |
							Click  Add and enter external hosts which should bypass the proxy when accessed. |
							| Authentication Type |
							Select the type of authentication used for the APN connection. |
							| Username |
							Enter the APN username provided by your wireless carrier. |
							| Password |
							Enter the APN password provided by your wireless carrier. |
