Add/Edit Application Run Control Entry: Path
This topic describes the remaining fields that appear in the Add/Edit Application Run Control Entry dialog box when you select Path in the Policy Type list.
File Path Enter the filepath of the application you want to restrict.
Exceptions
In this section of the dialog box you define any exceptions you want to allow for the restriction.
Add Click the Add button to open a menu from which you can select one of the following:
  • Publisher Exception: Opens a dialog box in which you can specify an exception to the restriction based on application publisher.
  • Path Exception: Opens a dialog box in which you can specify an exception to the restriction based on application filepath.
  • Hash Exception: Opens a dialog box in which you can specify an exception to the restriction based on application hash value.
Edit Click the Edit button to open a dialog box in which you can make any required changes to the exception that is currently selected in the exception list.
Delete Click the Delete button to delete the currently selected exception from the exception list.
