Feature Control (Phone)
Windows Phone 8.0: WP8.0
Windows Phone 8.1: WP8.1
Windows 10 Mobile: WP10
Hardware
| Feature Control Option | Description | Compatible OS |
| Disable NFC | Prevent the user from using Near Field Communication. | WP8.1, WP10 |
| Disable USB Connection (MTP/IPoUSB) | Disable the device from being connected as a Media Transfer Protocol client or IP over USB device through USB. This will block users from being able to transfer files from the device to a computer using USB. | WP8.1, WP10 |
| Disable Camera | Prevent the user from using the camera on the device. | WP8.1, WP10 |
| Disable Location Service | Disable any Location Services on the device. This will also block various applications on the device from using Location Services. | WP8.1, WP10 |
Application
| Disable Windows Store | Prevent users from installing or updating applications through the Windows Store. | WP8.1, WP10 |
| Disable Store Application Automatic Update | Disable automatic update of apps from Windows Store. | WP10 |
Cellular Data and Roaming
| Disable VPN Roaming Over Cellular | Do not allow users to enable VPN while the device is roaming. | WP8.1, WP10 |
| Disable VPN Over Cellular | Do not allow users to enable VPN while the device is on a cellular data network. | WP8.1, WP10 |
| Disable Cellular Data Roaming | Prevent the user from using cellular data while the device is roaming. | WP8.1, WP10 |
WiFi
| Disable WiFi | Prevent the device from connecting to a WiFi network, and disable WiFi. | WP8.1, WP10 |
| Disable Manual WiFi Configurations | Prevent users from manually configuring WiFi configurations on their device. | WP8.1, WP10 |
| Disable WiFi Hotspot Reporting | Disable WiFi hotspot information from being reported to Microsoft. | WP8.1 |
| Disable Auto Connect to WiFi Sense Hotspots | Prevent the device from auto connecting to WiFi hotspots. | WP8.1, WP10 |
Bluetooth
| Disable Bluetooth | Prevent the user from enabling Bluetooth. | WP8.1, WP10 |
| Telemetry Data Restriction Level | Defines the level of telemetry information (such as SQM, Watson) the device can send.
Allow – all available data will be sent. Disable – feature is disabled (no data will be sent). Disable Secondary Requests – third-party applications will not be able to send this data. |
WP8.1, WP10 |
| Disable Copy/Paste | Disable copy/paste functionality on the device. | WP8.1, WP10 |
| Disable Manual Installation of Root Cert | Prevent users from manually installing root certificates on the device. | WP8.1, WP10 |
| Disable Developer Unlock | Prevent the device from undergoing a developer unlock. | WP8.1, WP10 |
| Disable Browser | Disable the default browser on the device. | WP8.1, WP10 |
| Disable Screen Capture | Disable screen capture functionality on the device. | WP8.1, WP10 |
| Enable Internal Storage Encryption | Enable encryption on internal storage of the device.
Note: Once encryption is enabled, it cannot be disabled via policy. It can only be removed through a factory reset of the device.
WP8.0, WP8.1, WP10 |
| Disable SD Card Access | Disable access to the SD card directory. | ALL |
| Disable Internet Sharing Over WiFi | Disables the device from being able to share Internet and becoming a WiFi hotspot. | WP8.1, WP10 |
| Disable Direct Memory Access | Disable Direct Memory Access. | WP10 |
| Disable File Decryption by Users | Disable user file decryption. | WP10 |
Device Account
| Disable Microsoft Account Connection | Prevent users from connecting their devices to a Microsoft Account. | WP8.1, WP10 |
| Disable Adding Non-Microsoft Accounts Manually | Prevent users from connecting their devices to a non-Microsoft Account manually. | WP8.1, WP10 |
Search
| Disable Search to Use Location | Prevent the Bing search from using location services on the device. | WP8.1 |
| Safe Search Type | Enable safe search on the device. This setting prevents adult content from appearing in search results.
User Controlled – Allow the user to select safe search restrictions. Moderate – Moderate filtering against adult content (valid search results will not be filtered). Strict – Highest filtering against adult content. |
WP8.1, WP10 |
Device Lock
| Disable Idle Return without Password | Require the user to input the password every time the device is returning from idle state. (Requires the device password to be enabled.) | WP8.1, WP10 |
| Disable Action Center Notifications | Prevent Windows Action Center from displaying notifications on the device. | WP8.1, WP10 |
Experience
| Disable Voice Recording | Disable access to the voice recorder on the phone. | WP8.1, WP10 |
| Disable Syncing of Settings | Disable the syncing of settings between this device and other devices. | WP8.1, WP10 |
| Disable Cortana | Disable Cortana (personal digital assistant) on the device. | WP8.1, WP10 |
| Allow Manual MDM Unenrollment | Allow the user to unenroll the device. | WP8.1, WP10 |
| Disable Device Discovery on Lock Screen | Disable the device discovery user interface on the lock screen. | WP10 |
System
| Disable Factory Reset | Prevent the user from performing a hard reset (factory reset) on the device. | WP8.1, WP10 |
| Restrict Telemetry Data (WP 8.1) | Determines the amount of diagnostic and usage telemetry data sent to Microsoft. Choose one of the following levels:
WP 8.1 |
| Restrict Telemetry Data | Determines the amount of diagnostic and usage telemetry data sent to Microsoft. Choose one of the following levels:
Levels are listed in order of least to most data sent. |
WP 10 |
| Disable Location Service | Determines the status of Location Services on the device. Applications on the device will be blocked from using Location Services. Choose an option from the dropdown list:
WP 8.1, WP 10 |
| Disable SD Card Access | Prevents device user from accessing data on SD card. | WP 8.0, WP 8.1, WP 10 |
| Disable Windows Preview Builds | Prevents device user from downloading and installing Windows preview software. | WP 10 |
| Disable Embedded Mode | Prevents device user from entering Embedded Mode. | WP 10 |
| Allow Microsoft Experimentation | Allows Microsoft to conduct full experimentation to study user preferences or device behavior. | WP 10 (version 1703 or later) |
| Disable Font Providers | Prevents device user from downloading fonts and font catalog data from online font providers. | WP 10 (version 1703 or later) |
| Disable Factory Reset | Removes the ability to factory reset the device from the device user. | WP 10 |
| Telemetry Proxy | Specifies a proxy server through which to forward Connected User Experiences and Telemetry requests. Enter the fully qualified domain name (FQDN) or IP address of a proxy server. The format for this setting is server:port. The connection is made over a Secure Sockets Layer (SSL) connection.
If the named proxy fails, or if there is no proxy specified when this policy is enabled, the Connected User Experiences and Telemetry data will not be transmitted and will remain on the local device. |
WP 10 |
| Disable Data Sense Settings | Disallow the user to change Data Sense settings. | WP10 |
| Disable Date Time Settings | Disallow the user to change date/time settings. | WP10 |
| Disable VPN Settings | Disallow the user to change VPN settings. | WP10 |
| Disable Account Settings | Disallow the user to change account settings. | WP10 |
Update
| Phone Update Restrictions | Set the Windows Embedded Handheld Phone Update Restriction.
WP8.1 |
| Auto Update Settings | Allow the IT administrator to manage automatic update behavior to scan, download, and install updates.
WP10 |
| Disable Non-Microsoft Signed Update | Disallow the IT administrator to manage whether Automatic Updates accepts updates signed by entities other than Microsoft when the update is found at the UpdateServiceUrl location. This policy supports using WSUS for third-party software and patch distribution. Supported operations are Get and Replace. | WP10 |
| Disable Update Service | Specify whether the device can use Microsoft Update, Windows Server Update Services (WSUS), or Windows Store. Even when Windows Update is configured to receive updates from an intranet update service, it will periodically retrieve information from the public Windows Update service to enable future connections to Windows Update, and other services like Microsoft Update or the Windows Store. Enabling this policy will disable that functionality, and may cause connection to public services such as the Windows Store to stop working. Note: This policy applies only when the desktop or device is configured to connect to an intranet update service using the Custom Update WSUS server URL policy. |
WP10 |
| Scheduled Install Time (0-23 hours) | Enable the IT administrator to schedule the time of the update installation. | WP10 |
| Custom Update WSUS Server URL | The URL of a custom update WSUS server. Allows the device to check for updates from a WSUS server instead of Microsoft Update. This is useful for on-premises MDMs that need to update devices that cannot connect to the Internet. | WP10 |
| Scheduled Install Day | Enable the IT administrator to schedule the day of the update installation. | WP10 |
| Disable Adding Provisioning Package | Specifies whether to allow the runtime configuration agent to install provisioning packages. | WP10 |
| Disable Removing Provisioning Package | Specifies whether to allow the runtime configuration agent to remove provisioning packages. | WP10 |
| Disable Required Provisioning Package Signature | Specifies whether provisioning packages must have a certificate signed by a device trusted authority. | WP10 |
