VPN: Pulse Secure
Configure Pulse Secure VPN settings on your devices.
To exclude specific applications, namespaces or networks from the VPN, use the Applications, Name Space or Network tabs on the right side of the dialog box. Use the Windows Companion for SOTI MobiControl application to retrieve the necessary application information.
| Custom Configuration | Enter any custom configuration settings. |
| Trusted Network Detection | Enable/Disable Trusted Network Detection functionality. VPN will not connect when the user is on their corporate wireless network where protected resources are directly accessible to the device. DNS Suffix is required in order to detect the corporate wireless network. |
| Proxy | Choose between None or Manual. (If you choose Manual, the Proxy Server and Port fields become enabled.) |
| Proxy Server | The hostname or IP address of the proxy server. |
| Port | The port number of the proxy server. |
Connection Settings
