| Disable Location Service |
Determines the status of Location Services on the device. Applications on the device will be blocked from using Location Services. Choose an option from the dropdown list:
- User Controlled: Device user can switch location services on or off.
- Enabled: Location services are enabled and device user cannot disable them.
- Disabled: All location services are disabled and no applications can access location information. Device user cannot enable them.
| Restrict Telemetry Data |
Determines the amount of diagnostic and usage telemetry data sent to Microsoft. Choose one of the following levels:
- Security: Sends only data required to keep Windows secure
- Basic: Sends basic data such as device information, app compatibility and usage data and data from the Security level
- Enhanced: Sends security and basic data plus additional insights such as how Windows, Windows Server, System Center, and apps are used, how they perform, and advanced reliability data
- Full: Sends all data necessary to identify and solve issues plus data from the Security, Basic and Enhanced data levels.
Levels are listed in order of least to most data sent.
