Configure Download Location
Specify the location on the device where SOTI Surf saves files downloaded from the internet. This option only applies to files downloaded from sites that are not routed through ERG. Downloads from sites routed through ERG are saved in an application sandbox. The download location must be a location in the device's internal storage, for example, %sdcard% or a defined directory path. Directory paths cannot begin or end with /
or \
. They also cannot contain any of the following characters: ' " ` % \ + : * ? < >
Tip: Leave the download location field blank to save downloads to the root level.
If a device has multiple profiles with conflicting download location settings, settings from the profile that was created first will be used.
Download Location | Enter a location on the device where SOTI Surf will store files downloaded from the internet. |
