WiFi (Android Enterprise)
Network Name The name of the network to which the device should connect. This is also the name of the Wireless Policy.
Security Type Select the security protocol to use on the network. You can select WEP, WPA/WPA2, 802.1x Enterprise or None.
Password Enter a password to connect to the network.
Enterprise Settings Click on this field if you selected 802.1x Enterprise as the Security Type. It will open the 802.1x Enterprise settings page.
See 802.1x Enterprise Settings below for more information on the 802.1x Enterprise settings panel.
Proxy Choose a proxy type
  • Choose Automatic to enter a PAC URL used to receive proxy settings
  • Choose Manual to enter proxy settings manually
  • Choose None if you do not want to use a proxy for the WiFi connections
URL Enter a URL to the Proxy Auto-Configuration (PAC) file containing the proxy settings.
This option is only available if Automatic is selected as the Proxy type.
Proxy Server Enter the address for the proxy server.
This option is only available if Manual is selected as the Proxy type.
Port Enter the port number for the proxy server.
Exceptions Enter any host exceptions that you want to connect directly to instead of through the proxy.
Use commas to separate host exceptions.
When 802.1x Enterprise is selected as the Security type, click on the Enterprise Settings text field to open a pop-up window.
On the Protocols tab, you can select TLS, LEAP, EAP-FAST, TTLS, and/or PEAP.
The Authentication tab has the following options for configuring the 802.1x settings:
Username Enter the user name, or enter a macro used to set the user name.
Password Enter the password for the provided user name.
Use Identity Certificate Select a certificate used to connect to the wireless network.
Only certificates that have been uploaded to SOTI MobiControl appear in this list.
CA Certificate Select a CA certificate used to verify the wireless network connection.
Phase 2 Authentication Select the Phase 2 authentication protocol to use.
Anonymous Identity Enter an externally visible identification for the wireless connection (for TTLS, PEAP, and EAP-FAST only).
When you have finished configuring the 802.1x enterprise settings, click Save and Close to close the pop-up window.
