Lockdown (Android Enterprise)
Lockdown replaces the standard device home screen with a customizable home screen that provides access only to authorized applications and websites.
New | Opens the Add Menu Item dialog box in which you can specify the settings for a new Lockdown menu item. |
Edit | Opens the Add Menu Item dialog box in which you can edit the settings for the selected Lockdown menu item. |
Delete | Deletes the selected Lockdown menu item. |
Move Up | Moves the selected menu item one position higher in the menu order. |
Move Down | Moves the selected menu item one position lower in the menu order. |
Templates | Opens the Edit Menu Template List dialog box in which you can add, edit, or delete the menu items that appear in the template list. |
Advanced | Opens the Advanced Lockdown Settings dialog box in which you can specify advanced settings for Lockdown mode. |
