SOTI Surf
Privacy
Specify Privacy Settings Click the Configure button to open the Configure Privacy Settings dialog box in which you can specify the browsing capabilities of the SOTI Surf app.
Filtering
Enable Intranet Gateway Select this option and click the Configure button to open the Configure Intranet Gateway Settings dialog box in which you can specify the details of the Enterprise Resource Gateway you want SOTI Surf to use.
Enable Website Filtering Select this option and click the Configure button to open the Configure Website Filtering dialog box in which you can block websites based on their URL or content type.
Others
Enable Home Screen Select this option and click the Configure button to open the Configure Home Screen dialog box in which you can set a specific website as the home screen of SOTI Surf or display a curated set of website links.
Enable Kiosk Mode Select this option and click the Configure button to open the Configure Kiosk Mode Settings dialog box in which you can specify kiosk mode (reduced functionality) settings.
Export browsing history to a file Select this option and click the Configure button to open the Configure File Location dialog box in which you can specify a location for file containing browser history.
Specify Application Settings Click the Configure button to open the Configure Application Settings dialog box where you can modify the settings of the SOTI Surf app.
Specify Network Settings Click the Configure button to open the Configure Network Settings dialog box in which you can specify the type of network you want to configure for browsing.
App Shut Down Time Specify the time (in minutes) between when a configuration change is pushed to the device and when the app is forced to shut down and apply the update, requiring device users to log in again.
If a device has been assigned multiple SOTI Surf configurations with conflicting app shutdown times, the configuration that was created first applies.
Enable LDAP Login When this option is enabled, devices users must use their LDAP credentials to log into SOTI Surf. You must have intranet gateway settings configured to use this option.
If a device has been assigned multiple SOTI Surf configurations with conflicting Enable LDAP Login settings, the configuration with LDAP enabled applies. If multiple SOTI Surf configurations have LDAP enabled but with differing inactivity timeouts, the timeout period specified in the configuration that was applied first supersedes the subsequent configurations.
Inactivity Timeout Specify the user inactivity time (in minutes), after which the user will be logged out. Enter 0 to disable inactivity timeout for the browser.
