Task Scheduler
Use the Task Scheduler profile configuration to send scripts to your devices and execute them according to a configured schedule.
| Add | Select to add a new script to the Task Scheduler profile configuration. |
| Edit | Select to edit an existing script in the Task Scheduler profile configuration. |
| Delete | Select to remove a script from the Task Scheduler profile configuration. |
