Settings Manager
The Settings Manager app enables you to provide controlled access to a subset of device settings while a device is in lockdown mode. Choose from the device settings below when configuring the Settings Manager app using the Settings Manager profile configuration.
Display
| Setting in Profile Configuration | Description | Setting In XML Configuration |
| Adaptive Brightness | When enabled, the device user can control the adaptive brightness setting for their device. | brightnessSeek |
| Brightness | When enabled, the device user can set the brightness level of their display. | brightnessAuto |
| Screen Rotation | When enabled, the device user can decide if their display remains in Portrait mode persistently or rotates automatically as the device changes position. | AutoRotate |
| Screen Timeout | When enabled, the device user can set a period after which the device screen times out and goes to sleep. | screenTimeout |
Sound
| Ringtone Volume | When enabled, the device user can control the volume of the ringtone on their device. | ringtoneVolume |
| Media Volume | When enabled, the device user can control the volume of any media they play on their device. | mediaVolume |
| Notification Volume | When enabled, the device user can modify the volume of their device's notifications. | notificationVolume |
| System Volume | When enabled, the device user can control the volume of their device. | systemVolume |
WiFi
| Enable | When enabled, the device user has access to WiFi connectivity settings. | wifiOnOff |
| Scan | When enabled, the device can scan for available WiFi networks. | wifiScan |
Bluetooth
| Enable | When enabled, the device has access to Bluetooth. | btOnOFf |
| Visible | When enabled, the device is visible to other Bluetooth enabled devices. | btMakeVisible |
| Pair | When enabled, the device can pair with other Bluetooth enabled devices. | btPairUnpair |
| Scan | When enabled, the device can scan for other visible Bluetooth enabled devices. | btScan |
