New/Edit Phone Calls
This dialog box lists the phone numbers to which you want to block or allow access. Use this dialog box to add, edit, or delete phone numbers.
| Name | Enter a descriptive name you want to give this list of phone numbers. |
| Type | Select whether you want to allow or deny access to this list of phone numbers. |
| Direction | Select the phone call direction you want to allow or deny for this list of phone numbers: incoming, outgoing, or both. |
| Add | Enables you to add a phone number to the list. Note: The phone number must contain only numbers. Do not include number group separators such as dashes or spaces. |
| Edit | Enables you to edit the selected phone number in the list. |
| Delete | Deletes the selected phone number from the list. |
| Import Phone Numbers | Opens a dialog box in which you can select a text file that contains a list of phone numbers you want to import. Note: The imported file must
Using Wildcard Characters
SOTI MobiControl supports the use of the asterisk (*) and question mark (?) wildcard characters to indicate a range of phone numbers. An asterisk matches zero or more digits, and a question mark matches one digit.
    4445551230
    4445551231
    4445551232
    4445551233
    4445551234
    4445551235
    4445551236
    4445551237
    4445551238
    4445551239You can also use the two wildcard characters in combination. For example, 4??55512* would match 4325551234, but not 4324321234.
