Use this dialog box to configure a user password policy.
		Complexity Requirements
							| Minimum Password Quality | Select the minimum password quality. |
							| Minimum Password/PIN Length | Select the minimum password or PIN length. |
							| Minimum Number of Complex Characters Allowed | Select the minimum number of complex (non-alphanumeric) characters required. |
History
							| Maximum Password Age | Enter the number of days before the user is prompted to enter a new password. |
							| Number of Unique Passwords Before Reuse | Select the number of unique passwords a user must set before a previous password can be reused. |
Policy
							| Maximum Setting Allowed for Screen Timeout | Select this option to set a maximum inactive time before the screen locks. |
							| Maximum Number of Failed Password Attempts Before Device Wipe | Select the number of times an incorrect password can be entered before the device is automatically wiped. |
							| Common Access Card (CAC) Authentication | Select this option to use Common Access Card (CAC) authentication. |
