Enabling Groups
Enable a disabled group.
Note: You can enable, rename or delete a
disabled group
To enable a group:
- From the main menu, select
To enable a group, select on the left of the
group name you wish to disable (see blue box below).
- In the pop-up menu, select Enable (see red box above).
In the Enable Group panel, select the Yes, please enable this
group checkbox.
- Select Enable.
