Authentication (Android Classic)
The Authentication configuration enables you to set minimum requirements for password-based user authentication on a device. You can apply this configuration when:
| Password | Enter an administrator password for the device that turns off security features such as Lockdown or Application Run Control. |
| Dynamic Password | Enable this feature to set a unique one time administrator password for the
									device(s), allowing seamless switching between user and
									administrator modes. When you use the password, SOTI MobiControl automatically generates a new
									password and syncs it with the device. You can view this on the
										Device Details card. Note: If the device goes offline and the new
										password is not synced, the old password continues to work
										until the new password is successfully
											synced.
| Revert to User Mode | Enable this option to automatically switch from Administrator mode to User mode after
									a specified timeout time. Use the slider to set the interval
									between 5 and 120 minutes, with a default setting of 30
											minutes.
| Restrict Administrator Password Attempts | Restrict the number of password attempts a user can make for
									an administrator account before enforcing a lockout. Specify the
									number of wrong password attempts allowed before the account is
									temporarily locked. Set the duration of the account lockout once
									the user reaches the maximum number of password
											attempts.
Device User Password Policy
Turn on Password Policy Type to set complexity requirements and other password policies for the device user.
Note: You must specify a device administrator password before you can configure a user
				password policy.
		Minimum Complexity
| Password Quality | Select the minimum password quality. Password quality options
								listed are in order of security strength, from least to most secure.
								Device users can use any password type option that is more secure
								than the selected minimum.
| Password/PIN Length | Set the minimum password or PIN length. Tip: For PIN
									length, the default value is 6. You can set it between
									4—16. |
| Complex Characters | Set the minimum number of complex (non-alphanumeric) characters required. |
History
| Maximum Password Age | Toggle on Maximum Password Age to enter the number of days before prompting a user to enter a new password. |
| Unique Passwords Before Reuse | Toggle on Unique Passwords Before Reuse to select the number of unique passwords a user must set before reusing an earlier password. |
Policy
| Screen Timeout | Toggle on Screen Timeout to set a maximum inactive time before the screen locks. |
| Device Authentication Wipe Policy | Toggle on Device Authentication Wipe Policy to set a maximum limit on entering wrong passwords before a device is automatically wiped. |
| Common Access Card (CAC) Authentication | Select this option to use Common Access Card (CAC) authentication. |
