View System Overview
To view the System Overview dashboard:
  1. Select System Health from the main menu.
  2. From the System Health tree on the left, select System Overview to display the System Overview page.
  3. Scroll up/down and left/right to display the required information.
  4. Hover over the status icons (by the component names) to display the verbal status descriptions.
  5. To update the displayed information, select the Refresh icon in the top-right corner of the page.
  6. To view the details of a Deployment server, select this server's name in the Deployment Servers section.
    You can access the selected server's stats on a separate page (see Deployment Server Stats).
  7. To view the details of a Management server, select this server's name in the Management Servers section.
    You can access the selected server's stats on a separate page (see Management Server Stats).
  8. Under the SOTI Search section: The node with the Primary identifier is the server SOTI MobiControl interacts with.
Example
