Deleting a File Uploaded to the Content Library
Use this procedure to remove an uploaded file from the Content Library.
- There are several ways to reach the Content Library. In this example, select . The legacy console opens.
- From either the Android Plus or Apple platform tab, select the Content Library tab.
				Right-click the file that you want to delete and select
						Delete.
- Select OK.
Deleted files are removed from devices during the next synchronization.
