Remote Controlling Devices Using SOTI Xsight
You must have SOTI Xsight installed to use this feature.
Note: Zebra Android Enterprise devices do not require a plugin to support remote control. However, when a remote-control session is established via the Zebra RC API, a pop-up appears on the device screen, prompting the device user for a remote-control permission. The pop-up can be suppressed by API means on devices with MX 9.3 or later. The suppression does not work on TC20 and TC25 devices.
- Select the device that you want to remote control and click the Remote Control icon in the Device Actions menu bar.
- In the Remote Control dialog box, select Web-based and click OK.
SOTI MobiControl will launch SOTI Xsight in a new browser tab where the remote control session will begin. See SOTI Xsight Help for more information.
