Email: Exchange Active Sync
The Exchange Active Sync email configuration enables you to configure Microsoft Exchange email settings for your devices when:
Account Description
| Email Address | Enter the email address associated with your exchange account. Supports macros. |
| User | Enter the user name associated with your exchange account. Supports macros. |
| Domain | Enter the domain name of your organization. |
| Server | Enter the IP address or hostname of your Exchange Server. If you use Enterprise Resource Gateway to route your traffic, enter the IP address or hostname of the proxy server instead. Read Using Enterprise Resource Gateway (ERG) Servers for more information. Note: This field is case sensitive. |
| Use SSL | This option allows the end user to select whether or not SSL is used for communication with the Exchange server. |
| Sync the Past | Select how far back to synchronize past emails. |
| Sync Interval | Select the interval between the email synchronizations. |
