Branding the Login Page
You can select a custom logo to appear on the SOTI MobiControl login page.
To select a custom logo:
  1. Select Global Settings from the main menu.
  2. From the Settings tree on the left, select Branding > Login Page.
  3. In the Login Page page that opens (see Login Page), remove the current logo (if any):
    1. Click the Delete icon displayed over the current logo.
    2. Click Delete in the warning message that appears.
  4. Do one of the following:
    • Click the Browse File link in the Custom Logo field, then browse for an image file for the new logo.
    • Drag an image file for the new logo and drop it into the Custom Logo field.
  5. Click Save.
