Branding the Self Service Portal Header
You can select a custom logo to appear on the Self Service Portal's header.
Note: The maximum image dimensions are 120 × 30 pixels. The maximum file size is 1 MB.
			To select a custom logo:
- From the Settings tree on the left, select .
- In the Self Service Portal page that opens (see Self Service), click the Delete icon displayed over the current logo.
- Click Delete in the confirmation message that appears.
				Do one of the following:
				- Click the Browse File link in the Custom Logo field, then browse for an image file for the new logo.
- Drag an image file for the new logo and drop it into the Custom Logo field.
- Click Save.
