Branding the Administrative Console
You can select a custom logo to appear in the top navigation bar of the SOTI MobiControl console.
Note: A transparent, rectangular image is recommended. The image will be scaled to 32px in height. The maximum file size is 1 MB.
To select a custom logo:
  1. Select Global Settings from the main menu.
  2. From the Settings tree on the left, select Branding > Administrative Console.
  3. In the Administrative Console page that opens (see Administrative Console), remove the current logo (if any):
    1. Click the Delete icon displayed over the current logo.
    2. Click Delete in the confirmation message that appears.
  4. Do one of the following:
    • Click the Browse File link in the Custom Logo field, then browse for an image file for the new logo.
    • Drag an image file for the new logo and drop it into the Custom Logo field.
  5. Click Save.
