Remote Controlling Devices Using the SOTI MobiControl Plugin
Note: This is a legacy feature. Whenever possible, use SOTI Assist for remote control sessions.
Note: Zebra Android Enterprise devices do not require a plugin to support remote control. However, when a remote-control session is established via the Zebra RC API, a pop-up appears on the device screen, prompting the device user for a remote-control permission. The pop-up can be suppressed by API means on devices with MX 9.3 or later. The suppression does not work on TC20 and TC25 devices.
  1. Select the device that you want to remote control and click the Remote Control icon in the Device Actions menu bar.
  2. In the Remote Control dialog box, select Downloadable Plugin (Legacy) and click OK, then Download to download the plugin.
  3. Run the plugin installer as an administrator to install the plugin on your computer.
    The plugin installer is an .msi file that can be run only on Windows computers.
  4. Restart your browser to apply the plugin.
  5. Select the device that you want to remote control and click the Remote Control icon in the Device Actions menu bar to initiate a remote control session on the device.
Note: On the Microsoft Edge browser, Enhanced Protected Mode (EPM) is enabled by default. EPM can block the connection required for the remote control plugin. If blocked, Edge may prompt you to continuously reinstall the SOTI MobiControl plugin for Remote Control. To correct this issue, open Windows PowerShell as an administrator and run the following command: CheckNetIsolation LoopbackExempt -a -n="Microsoft.MicrosoftEdge_8wekyb3d8bbwe"
