Display Name |
Enter the name of the APN connection as seen by the Windows Connection Manager. |
Access Point Name (APN) |
Enter the name or web address of the access point provided by your wireless carrier. |
Access Point Type |
Select the access point type. |
Roaming |
Specify whether the connection should be activated when the device is roaming. |
SIM Card ICCD |
Specify the SIM Integrated Circuit Card ID (ICCID) that services this connection. Use this option with dual-SIM card devices to determine which SIM card will be used for the APN connection. |
Enable Proxy |
Select this option the enable the use of an HTTP proxy. |
Hostname |
Enter the name and port number of the proxy server. |
Bypass Local |
Select this option to enable the proxy to be bypassed when local hosts are accessed by the device. |
Exception List |
Click Add and enter external hosts which should bypass the proxy when accessed. |
Authentication Type |
Select the type of authentication used for the APN connection. |
Username |
Enter the APN username provided by your wireless carrier. |
Password |
Enter the APN password provided by your wireless carrier. |
