Configuring Remote Control Plugin Settings
Note: These settings are only applicable to the remote control sessions initiated through the plugin, not SOTI Assist.
			To change connection profiles and skin settings for remote control sessions:
- Click a device name to open its Device Information panel.
 - Switch to the Configurations tab and scroll down to the Advanced Configurations table.
 - Open Remote Control Settings and modify its settings as needed.
 - Click Save to save your new settings.
Note: You can also modify remote control settings at the device group level by following the same general steps. Open a Group Information panel and edit Remote Control Settings in the Advanced Configurations table of the Configurations tab. You will need to modify the setting for each applicable device family present in a device group.
