Remote Controlling Devices Using SOTI Assist
You must have SOTI Assist installed to use this feature.
- Select the device that you want to remote control and click the Remote Control icon in the Device Actions menu bar.
 - In the Remote Control dialog box, select Web-based and click OK.
SOTI MobiControl will launch SOTI Assist in a new browser tab where the remote control session will begin. See SOTI Assist Help for more information.
