Email: IMAP Account
Connection
Account Name Specify Account Name or Description.
IMAP Prefix Specify IMAP Incoming Server Prefix.
Mail
Email Notification Choose what to do for email notification.
Sync Interval Frequency of synchronization.
Signature String to be used as the signature of the sender.
Common Access Card Authentication Use Common Access Card (CAC) for authentication.
Incoming Server
Host Address Enter the IP address or hostname, and (optionally) the port number, of the email server.
Security Select the protocol used for mail data communication.
User Enter the user name. Supports the following macros: %EnrolledUser_Upn%, %EnrolledUser_Domain%, %EnrolledUser_Username%, %Prompt%.
Authentication Type Select the server authentication method.
Password Enter the password associated with the user entered above.
Email Configuration Enter email address for the device. E.g., bob.smith@mycompany.com. Supports the following macros: %EnrolledUser_Email%, %Prompt%.
Outgoing Server
Host Address Enter the IP Address or hostname, and (optionally) the port number, of the email server.
