APN
Display Name | Enter a name for the APN that is displayed on the device. |
Access Point Name (APN) | Enter the name or web address of the access point provided by your wireless carrier. |
Mobile Country Code (MCC) | Select the three digit code, as defined by the ITU, that identifies the network's country of origin. |
Mobile Network Code (MNC) | Select the mobile network code. The list contains all available mobile networks in the selected country.
This option only appears after a Mobile Country Code is selected. |
Access Point Type | Select the access point type. |
Access Point Custom Type | Enter the custom access point type.
This option only appears if Any Type is selected as the Access Point Type. |
MVNO Type | Select the type of mobile virtual network operator (MVNO). |
MVNO Value | Enter a value for the mobile virtual network operator (MVNO).
This option only appears after a MVNO Type is selected. |
Default Connection | Select this option to make this the default APN connection for devices. |
Server
Access Point Connection Username | Enter the APN username provided by your wireless carrier. |
Access Point Connection Password | Enter the APN password provided by your wireless carrier. |
Host Address | Enter the hostname or IP address and port number of the server provided by your wireless carrier. |
Proxy Server Address | Enter the hostname or IP address of the proxy server. |
MMS Proxy Server Address | Enter the MMS proxy server address provided by your wireless carrier. |
MMS Server Address | Enter the MMS server address provided by your wireless carrier. |
Authentication Type | Select the type of authentication used for the APN connection. |
