Copying a Report Schedule
To save time you can create a new report schedule by creating a copy of an existing schedule and modifying it.
To create a copy of a report schedule:
- On the appropriate platform tab, select the Reports tab.
				In the left pane, click on the report type whose schedule you want to copy.
				The report details appear in the right pane.
				In the right pane, in the Schedule section, click on the report schedule you want to copy to select it, then right-click on the schedule and select Duplicate Report Scheduling.
				A new copy of schedule opens in the Edit Schedule for Report dialog box.
 - In the Edit Schedule for Report dialog box, make the desired edits to the schedule.
 - When you are done, click OK to save the schedule changes.
The new copy of the report schedule appears in the Schedule section.
