Deleting a Report Schedule
To delete a report schedule:
- On the appropriate platform tab, select the Reports tab.
				In the left pane, click on the report type whose schedule you want to delete.
				The report details appear in the right pane.
				In the right pane, in the Schedule section, click on the report schedule you want to delete to select it, then right-click on the schedule and select Delete.
				A message box appears asking you to confirm that you want to delete the schedule.
 - In the message box, click Yes confirm the schedule deletion.
The selected report schedule is now deleted.
