Disabling a Report Schedule
To disable a report schedule:
- On the appropriate platform tab, select the Reports tab.
				In the left pane, click on the report type whose schedule you want to disable.
				The report details appear in the right pane.
 - In the right pane, in the Schedule section, click on the report schedule you want to disable to select it, then right-click on the schedule and select Disable Report Scheduling.
The selected report schedule is now disabled. If other schedules have been created for this report type, those schedules are not affected.
To re-enable a disabled report schedule, right-click on the schedule and select Enable Report Scheduling.
