Vendor Compatibility Matrix: Lockdown
Some device features may not be compatible with all MDM versions. Refer to the table below to see which features are supported by your MDM version.
| Feature Name | Generic | Plus | Samsung Signed | Amazon | Casio | DRS | Samsung ELM Signed | Honeywell | HTC | Huawei | Kyocera | Lenovo | LG | Motorola | Panasonic | Pidion | Sony |
| Hide Status Bar | n/a | n/a | MDM 3+ | n/a | n/a | n/a | MDM 4+ | n/a | n/a | n/a | n/a | n/a | n/a | n/a | n/a | n/a | n/a |
| Disable Status Bar Expansion | 2.2+ | 2.2+ | 2.2+ | 2.2+ | 2.2+ | 2.2+ | MDM 4+ | 2.2+ | 2.2+ | 2.2+ | 2.2+ | 2.2+ | 2.2+ | 2.2+ | 2.2+ | 2.2+ | 2.2+ |
| Disable Settings Changes | n/a | n/a | MDM 3+ | n/a | n/a | n/a | MDM 4+ | n/a | n/a | n/a | n/a | n/a | n/a | n/a | n/a | n/a | n/a |
