Feature Control: Android Enterprise
Device Functionality
Features
| Allow Camera | When enabled, device user can use the camera.
Android OS compatibility: 6.0 or later. Available on Managed Profile only. |
| Allow Factory Reset | When enabled, device users can erase all applications, settings and data from the phone's internal storage.
| Allow Safe Boot | When enabled, devices can be rebooted into safe boot mode. All third-party software is disabled in safe boot.
| Allow Smart Lock | When enabled, device users can use Smart Lock on Android which allows devices to unlock without a password when they are within 'safe' places that the device user sets.
If the Allow All Keyguard Features feature control option is enabled, Allow Smart Lock is automatically enabled too. Android OS compatibility: 6.0 or later. Available on Managed Profile only. |
| Allow SMS | When enabled, the device can send and receive SMS.
Available on Managed Device only |
| Allow Status Bar | When enabled, the status bar can be expanded to view the details of device notifications.
| Allow Keyguard Camera | When enabled, the device user can launch the camera app from the lock screen.
If the Allow All Keyguard Features feature control option is enabled, Allow Keyguard Camera will be automatically enabled too. Available on Managed Device only. |
| Allow Microphone | When enabled, the device user can use the device microphone to record audio.
| Allow Airplane Mode | When enabled, device users can turn on Airplane mode on the device.
Requires Android 9.0 or later on Managed Devices. |
| Allow Ambient Display | When enabled, device users can turn on the Ambient Display feature.
| Allow Device Volume | When enabled, the volume settings are visible to and changeable by the device user.
| Allow Printing | When enabled, device users can use the device's printing capabilities.
| Allow Certificate Management | When enabled, device users can modify stored Credentials (Certificates) in the device's settings.
| Allow App Management | When enabled, device users can modify or uninstall apps (and app data). This includes disabling the ability to force close an app, clear app data, app caches, and app default launch settings.
| Allow Outgoing Cellular Phone Calls | When enabled, device users cannot initiate outbound calls. Internet or Voice-over-IP (VOIP) are not blocked.
| Allow Location Sharing for Work Profile | When enabled, Location Sharing is permitted for all Managed Profile apps. Apps running in the Work profile will be unable to use device location information.
| Allow Skip App First Use Hints | When enabled, when a supported app launches for the first time, it will skip any introductory hints or tutorials. |
| Allow Date Time Management | When enabled, device users can modify the date time, and timezone settings on the device.
Available on Managed Devices running Android 9.0 or later. |
| Allow Screen Timeout Management | When enabled, device users can configure screen timeout settings on the device.
| Allow Brightness Configuration Management | When enabled, device users can configure brightness settings on the device.
Connectivity
Network Connections
| Allow Tethering Management | When enabled, device users can modify their device's tethering (sharing a mobile device's data connection with another device) settings.
| Allow Bluetooth Management | When enabled, device users can modify their device's Bluetooth settings.
| Allow WiFi Management | When enabled, device users can modify WiFi configurations in their device's settings.
| Allow VPN Management | When enabled, device users can modify their device's VPN settings.
| Allow Network Settings Reset | When enabled, device users can reset their network configurations from their device's settings.
| Minimum WiFi Security Level | Set the minimum Wi-Fi Security Level that the device can connect to. For example, if you set the minimum Wi-Fi security level to WPA, the device will not be able to connect to a WEP network.
Security Options
| Allow All Keyguard Features | When enabled, device users can use keyguard features on the lockscreen. Keyguard features include fingerprint authentication, viewing of notifications, smart lock access and camera access. Enabling Allow All Keyguard Features will automatically enable the other keyguard feature control options.
| Allow Fingerprint Authentication | When enabled, device users can use Google's fingerprint authentication framework to secure their devices.
If the Allow All Keyguard Features feature control option is enabled, Allow Fingerprint Authentication will be automatically enabled too. Android OS compatibility: 6.0 or later. Available on Managed Profile only. |
| Allow All Keyguard Notifications | When enabled, all notifications on secure lock screens are visible.
If the Allow All Keyguard Features feature control option is enabled, Allow All Notifications will be automatically enabled too. Available on Managed Device only. |
| Allow Account Creation | Specify whether device users can add new accounts to the device. Choose an option from the dropdown list
| Allow Doze Mode | When enabled, allows the device to restrict the SOTI MobiControl Android agent for battery optimization.
| Allow All System UI | When enabled, system UI alerts appear to device users. This includes toast messages, phone activities (including priority) system alerts, system errors and system overlays.
| Perform SafetyNet check on Device Check-in | When enabled, the SafetyNet check is performed on the device at every device check in, in addition to once daily. |
| Allow Copy/Paste between Work and Personal | When enabled, device users can copy text or images between the Work and Personal profiles.
Available on devices with work profiles only. |
| Allow Sensitive Notifications | When enabled, notifications from Android Enterprise Apps display all their details when they appear on secure lock screens.
If the Allow All Keyguard Features feature control option is enabled, Allow Sensitive Notifications will be automatically enabled too. Android OS compatibility: 6.0 or later. Available on Managed Profile only. |
| Allow Third Party Input Methods | When enabled, device users can enable additional third-party input methods such as keyboards on their devices. |
| Allow Installation from Unknown Sources | When enabled, device users can install apps that are not from the Google Play store.
| Allow Multi-User Control | When enabled, device users can add secondary users or remove previously added secondary users.
| Allow Mounting Physical External Media | When enabled, device users can mount physical external media (including SD cards) to their devices.
Available on Managed Device only. Note: This does not disable external media through the device's charging port. To accomplish that, use Allow USB File Transfer and USB Storage.
| Allow Sharing from Work to Personal Profile | When enabled, device users can use an app's Share function to share between apps on the Work profile to apps on the Personal profile.
Android OS compatibility: 5.1.1 or later. Available on Managed Profile only. |
| Allow Outgoing NFC | When enabled, devices users can use NFC to send data (only applies to apps in the Work Profile).
| Allow Bluetooth Contact Sharing | When enabled, device users can use Bluetooth to share contact information.
| USB Debugging | Determines who controls the device's ability to enter USB Debugging Mode.
| Allow USB File Transfer and USB Storage | When enabled, device users can transfer data using a USB connection or save to a USB storage device.
This option is enabled by default. Available on Managed Device only. |
