Event Configuration
Event Settings
Specify how the device should be disconnected from SOTI MobiControl to trigger the configured actions. You can specify in minutes, hours, days, or weeks. If you choose to set the action to repeat, you must also specify its repetition cycle.
Action
Use scripts to define actions. You can use both classic scripts and JavaScript scripts. SOTI MobiControl provides a few predefined scripts which you can select from the Execute Script dropdown list, but you can also create your own. To learn more, see Script Commands for Android Plus Devices.
