VPN: IKEv2
Configure IKEv2 VPN settings on your devices.
To exclude specific applications, namespaces or networks from the VPN, use the Applications, Name Space or Network tabs on the right side of the dialog box. Use the Windows Companion for SOTI MobiControl application to retrieve the necessary application information.
| Trusted Network Detection | Enable/Disable Trusted Network Detection functionality. |
| Proxy | Choose between None or Manual. (If you choose Manual, the Proxy Server and Port fields become enabled.) |
| Proxy Server | The hostname or IP address of the proxy server. |
| Port | The port number of the proxy server. |
Connection Settings
Authentication
| Authentication | EAP type authentication is selected. |
| EAP Host Scheme | Select either TLS Connection or CHAP Connection. |
| Identity Certificate | Specify Client certificate for authentication. |
| Enterprise Settings | Specify Trusted Certificates for authentication and specify Server Names expected from authenticated server. |
