Application Run Control
This dialog box lists the device restrictions that have been added to this Application Run Control configuration.
| Action on Device | Select the type of action you want this configuration to have on the device:
| Add | Click the Add button to open the Add/Edit Application Run Control Entry dialog box in which you can enter the details of the restrictions you want to add. |
| Edit | Click the Edit button to open the Add/Edit Application Run Control Entry dialog box in which you can make any required changes to the restriction that is currently selected in the list. |
| Delete | Click the Delete button to delete the currently selected restriction from the restrictions list. |
