Client PFX Certificates
Use a Client PFX Certificates configuration to distribute Client PFX certificates to Windows Modern devices. You can select an existing certificate or you can select a template that SOTI MobiControl will use to dynamically generate a certificate that is specific to each user and device. For information about how to create a certificate template, see Creating a Certificate Template.
Note: Client PFX certificates can be used on devices running Microsoft Windows 10 or later. Client PFX certificates installed on older devices will be ignored.
		| Select from these available certificates and templates | Lists the currently available certificates and templates.
| (Windows Modern Desktop only) Specify the type of certificate | Select whether you want the certificate to be installed in the Device store or the User store. |
