Automatic Method
The automatic method will automatically retrieve data from the SOTI MobiControl database, update information in the SOTI MobiControl database to point to SOTI XSight (required for creating incidents and remote control sessions), and add a new client ID and client secret to the SOTI MobiControl database.
Note: To use the automatic method, the SOTI XSight server must have access to the SOTI MobiControl database.
On the menu bar, click the main menu button
and select Settings. The SOTI XSight Settings view opens.
- On the left side of the settings view, click Integration. The current integration settings appear on the right side of the view.
- If it is not already enabled, clickEnable SOTI XSight Login Page. The Domains field and the Other Instances section appear in the view.
In the Domains field, enter the domain or domains you want to use for the SOTI XSight login page.
The SOTI XSight login page at any of these domains will log into this instance of SOTI XSight.
Click the
button in the Other Instances section. The Add SOTI MobiControl dialog box opens.
In the Add SOTI MobiControl dialog box, select Automatic and enter the required information.
See Adding a SOTI MobiControl Instance to learn about what information is required.
Click the Save button.
The save process will take a few seconds to perform the updates to the SOTI MobiControl database.
If the SOTI MobiControl server uses a different certificate than the SOTI XSight server, you need to download the SOTI MobiControl root certificate and install it on the SOTI XSight server.
- Log out and log back into SOTI XSight for the changes to take effect.
