Parameter Thresholds
The following settings are located on the Watchlist tab of the Analysis Profile setup wizard. Use them to control when alert notifications are sent for each device.
| Parameter | Description |
| Battery Discharge Rate | Devices whose battery discharge rate per hour exceeds the set threshold |
| Data Consumed | Devices whose total data consumed per month exceeds the set threshold |
| Memory Consumed | Devices whose total memory consumed exceeds the set threshold |
| Storage Consumed | Devices whose total storage used exceeds the set threshold |
| Last Virus Scan | Devices that have not run a virus scan within the set time duration |
| Last Device Check-In | Devices that have not checked-in within the set time duration |
| Last Device Location Reported | Devices that have not reported their location within the set time duration |
| Device Drop Events | Devices that have detected and reported device drop events exceeding the set threshold |
