Firmware Upgrade for Zebra devices
Download the appropriate firmware file for your printer model here.
Note: Refer to the Certified Device List to ensure that the firmware version is compatible with your SOTI Connect version.
Upload the firmware file to SOTI Connect file store.
Refer to Using the File Store for more information.
Select Download Firmware From File Store from the device
actions to download the firmware upgrade file.
Choose the relevant firmware upgrade file and select
Save.
- Verify the firmware version on the device information panel view to confirm the update is successful.
