Branding the Administrative Console
Customize the SOTI MobiControl console by uploading a logo that appears on the navigation menu.
Customizing the web console with an enterprise logo helps reinforce your organization's brand identity and creates a consistent visual experience for administrators. Select a custom logo to appear in the console's navigation menu. The logo remains in the menu when expanding or collapsing it.
Restriction: You must use a transparent, rectangular image no larger than 1
MB. SOTI MobiControl scales the uploaded image to 32 pixels in
height.
- From the SOTI MobiControl main menu, navigate to the Global Settings view.
- From the Global Settings view, navigate to . The Administrative Console view opens.
Enable the Customize logo for the console toggle.
Update the logo for the expanded and collapsed navigation bar.
In the collapsed navigation bar section, you can either upload a logo image or display up to 3 letters as the logo.
- Select Browse in the Logo field to browse for an image file for your logo.
- Select Save.
