Remote Controlling Devices Using SOTI XSight
You must have SOTI XSight installed to use this feature.
Refer to the SOTI XSight documentation on Diagnostics and Remote Control.
Note: Zebra Android Enterprise devices do not require a plugin to support remote control. However, when a remote-control session is established via the Zebra RC API, a pop-up appears on the device screen, prompting the device user for remote-control permission. The pop-up can be suppressed by the API on devices with MX 9.3 or later. The suppression does not work on TC20 and TC25 devices.
  1. Select the device that you want to remote control and select the Remote Control icon in the Device Actions menu bar.
  2. In the Remote Control dialog box, select Web-based and select OK.
SOTI MobiControl launches SOTI XSight in a new browser tab to begin the remote control session.
