Create and Assign Compliance Policy
Create and assign a compliance policy in SOTI MobiControl to report compliance status to Microsoft.
- From the SOTI MobiControl main menu, select .
- Select New Compliance Policy. The Create Compliance Policy panel appears.
- Select the necessary platform. The Create Compliance Policy window appears.
- Enter a name for the policy then select Next. The Non-Compliance Policy screen appears.
- Select Add a Filter then select Device Mode as Is Not Active. Then, select Done.
Select
beside Policy Actions then, from the Action Type drop-down menu, select
Set Azure Conditional Access.
- Select Add Action. The action is added to the policy.
- Select Save or Save And Assign.
