Assign Profile: Options
Use this dialog box to specify profile assignment options. For a detailed procedure, refer to Assigning a Profile.
Installation
Choose the profile installation method, the device network types you want to enable for profile assignment, and the minimum device battery level for assignment.
| Installation Method | Choose how to install the profile's content on the device(s):
| Installation Priority | Select the priority value for a profile to establish its precedence over other
								profiles during installation. This does not affect the installation
								of non-prioritized profiles. Note:  Value 1 is the highest and
									ensures that the profile installs first. |
| Halt Installation of Lower Priority Profiles | This toggle enables administrators to halt the installation of lower priority
									profiles. Note: If this profile fails to install, SOTI MobiControl halts the installation of all
									lower prioritized profiles. |
| Network Restrictions | Specify the networks the device can use to download profile contents. |
| Minimum Battery Level | Set a minimum battery level required to begin installation. |
Package Options
Select options for package storage on the device, when package installation or re-installation should occur, and when to uninstall the package.
| Store Packages Persistently | When enabled, packages remain in the device's persistent storage to be re-deployed after a factory reset or a cold reboot. |
| Reinstall Every Update Schedule and Check-in | When enabled, the device reinstalls packages based on the update schedule and each time it checks in with the server. |
| Uninstall Contents After Profile Revocation/Deletion | When enabled, this option removes package contents from the device(s) when removing or deleting the profile. |
| Install Date | Set a date and time for installing the package on the device. Choose which time standard to use: Device Time or UTC Time. |
| Custom Package Installation Schedule | Set time frames for installing the packages. You can set many time frames. Select Add to add a time. Select Edit to edit an existing one. |
Profile Deployment Actions
Specify the time and date to assign, disable or revoke the profile.
| Assign Date | Enable to select a date and time to assign the profile. If you also enable Delay to next update schedule, profile assignment takes place on the first update check-in following the assign date. |
| Disable Date | Enable to select a date and time to disable the profile. |
| Revoke Date | Enable to select a date and time to revoke the profile. |
| Custom Deployment Schedule | Set time frames for installing the contents of the profile. You can set many
								time-frames. Select the Add button to add a
								time-frame. Note: You can set a profile assign date/time and a
									time-frame. If the assigned date/time is outside the time-frame,
									the profile is not automatically installed. It deploys only if
									the device checks in during the time-frame and after the assign
									date. The time-frame start does not trigger a
									check-in. Note: The download duration of packages may
									exceed the custom deployment time-frame based on their number
									and size. Downloads complete even if they exceed this
									time-frame. If interrupted by a device going offline, the
									download resumes from where it left off once the device is back
									online. |
Profile Scheduling
Assign and revoke profiles from devices based on a recurring weekly schedule for the selected days of the week. Based on the set profile schedule, the server requests all assigned devices to check-in at the time of assignment to apply the profile. The server requests all assigned devices to check-in at the time of revocation to remove the profile.
| Start Day | Specify the day of the week to assign the profile to the selected devices. |
| Start Time | Specify the time of the day to assign the profile to the selected devices. Note: The time zone corresponds to the server’s
									local time. |
| End Day | Specify the day of the week to revoke the profile from the selected devices. |
| End Time | Specify the time of the day to revoke the profile from the selected devices. Note: The time zone corresponds to the server’s
									local time. |
