Settings Manager Settings
The Settings Manager app provides controlled access to a subset of device settings while a device is in lockdown mode. Choose from the listed device settings when configuring the Settings Manager app using the Settings Manager profile configuration. Do this when you perform the following actions:
Display
Setting in Profile Configuration Description Setting In XML Configuration
Adaptive Brightness Control the adaptive brightness setting for the device. brightnessSeek
Brightness Set the brightness level of the display. brightnessAuto
Screen Rotation Set the display to remain in portrait mode persistently or rotate automatically as the device changes position. AutoRotate
Screen Timeout Set a period after which the device screen times out and goes to sleep. screenTimeout
Sound
Ringtone Volume Control the volume of the ringtone on the device. ringtoneVolume
Media Volume Control the volume of any media they play on the device. mediaVolume
Notification Volume Adjust the volume of notifications on the device. notificationVolume
System Volume Control the volume of the device. systemVolume
WiFi
Enable When enabled, the device user has access to Wi-Fi connectivity settings. wifiOnOff
Scan When enabled, the device can scan for available Wi-Fi networks. wifiScan
Add When enabled, the device user can add new Wi-Fi networks. wifiAdd
Modify When enabled, the device user can change Wi-Fi network settings. wifiModify
Mobile Data
Enable When enabled, the device user has access to device cellular data settings. configureMobileDataOnOff
Bluetooth
Enable When enabled, the device has access to Bluetooth. btOnOFf
Visible When enabled, the device is visible to other Bluetooth enabled devices. btMakeVisible
Pair When enabled, the device can pair with other Bluetooth enabled devices. btPairUnpair
Scan When enabled, the device can scan for other visible Bluetooth enabled devices. btScan
Time Zone
Enable When enabled, the device has access to Time Zone. timeZoneOnOff
Manual Sync to SNTP server When enabled, the device can synchronize with the SNTP server to manually update the date and time. syncWithSntpServer
SNTP Server The device can synchronize and update the date and time according to the defined server. sntpServer
Manage Access Point Name
Manage Access Point Name When enabled, the device user can create, change, view and delete the APNs. manageAccessPointNameOnOff
Manage Device Security
Manage Device Security When enabled, the device user can set new pin or password. manageDeviceSecurityOnOff
Flashlight
Flashlight When enabled, the device user can use device flashlight. flashlightOnOff
