Signal Policy Examples
The following Signal Policy use case examples illustrate how you can check and action devices, location zones, and servers. See Creating a New Signal Policy for more information.
Delete Enterprise Critical Apps when Exiting an Outdoor Geofence
This example monitors corporate-owned Android devices to make sure they remain within a highly controlled office environment. If a device exits the designated area, it represents a critical security breach, necessitating the deletion of any Enterprise Critical Applications on the device.
Condition 1
Category | Managed Device |
Type | Event |
Attribute | Device Exits Geofence |
Operator | [] IN |
Value | HQ-Ontario Office |
Condition 2
Type | Property |
Attribute | Device Kind |
Operator | [] IN |
Value | Android Enterprise, Android Plus |
- Exit Outdoor Geofence
- Device Kind
Action
Action | Send Script |
Type of action | Server Initiated |
Script Type | JavaScript |
Subject | Delete Enterprise Critical App on the device |
Delivery Method | SOTI MobiControl Device Agent |
Monitoring Device Roaming Data
This example monitors Android devices on the Verizon wireless carrier that have entered a roaming area where extra cellular charges might apply. The device is then moved to a device group configured with a profile that has no mobile network access as a follow up action.
Condition 1
Type | Event |
Attribute | Device is Roaming |
Condition 2
Type | Property |
Attribute | Cellular Carrier |
Operator | = IS |
Value | Verizon |
Condition 3
Type | Property |
Operator | [] IN |
- Device is Roaming
- Cellular Carrier
- Device Kind
Action
Action | Relocate Device |
Relocate device to | No Mobile Network Access Group |
Device Connection Policy
This example monitors managed devices and triggers an alert in the SOTI MobiControl Notification Panel and sends a message to the devices if they connect to a specific network.
Condition 1
Type | Property |
Attribute | IP Address |
Operator | CONTAINS |
Value | 172.16.16 |
Condition 2
Type | Property |
Attribute | Device Family |
Operator | [] IN |
Value | Android Plus, Windows Mobile/CE |
- IP Address
- Device Family
Action 1
Action | Trigger Alert |
Alert Title | %POLICYNAME% |
Message | Device connected to Experimental Network. |
Action 2
Action | Send Message |
Display Duration | 5 Seconds |
Type | Information |
Cloud Link Agent Status
This example monitors Cloud Link Agent status and triggers an alert in the SOTI MobiControl Notification Panel and sends an email on deleting the Cloud Link Agent.
Condition 1
Category | Cloud Link Agent |
Type | Property |
Attribute | Cloud Link Agent Name |
Operator | [] IN |
Value | CLA |
Condition 2
Type | Event |
Attribute | Cloud Link Agent Deleted |
- Cloud Link Agent Name
- Cloud Link Agent Deleted
Action
Action | Send Email |
Priority | Normal |
Send From | SMTP Server |
To | admin.company@soti.net |
Subject | Cloud Link Agent Deleted |
Message | Cloud Link Agent
%CLANAME% removed. |
