Bypassing the Activation Lock
Important: Complete this procedure before wiping your iOS/macOS
				devices. If you do not, you must manually enter the bypass code on your device.
			Note: When transferring from another MDM or SOTI MobiControl instance, SOTI MobiControl cannot retrieve the Activation Lock bypass code from
				devices that are not factory reset.
To automatically bypass the Activation Lock on iOS/macOS devices:
				Select the devices with Activation Lock enabled, and from the Device
						Actions bar, select
					 icon in the Device Actions menu bar.
- If applicable, select the warning message at the bottom of the dialog box to see why SOTI MobiControl cannot bypass the Activation Lock on some selected devices.
- Select Bypass Activation Lock.
What to do next
You can now wipe your iOS/macOS devices.
