Using Geofences
Geofences are virtual boundaries that you can apply to your devices to track and regulate their movement. SOTI MobiControl can perform actions when a device enters or exits an area covered by a Geofence.
Geofence actions include:
- Sending notifications to the web console and to devices
- Relocating the device to another device group
- blocking access to certain services
Android Original Equipment Manufacturer (OEM)-specific agents, Samsung ELM, and Android Enterprise agents all support the Geofence feature.
To set up notifications and actions for devices entering and exiting a Geofence, create a Geofence Signal Policy.
