Deleting a Geofence
Remove a defined geofence:
  1. Open a device's Device Information panel and switch to its Location tab.
    Note: The Location tab is not visible on devices where location services are not available.
  2. Select the Geofences icon in the Location menu bar and select the Delete button beside the geofence that you want to remove.
