Set Device Wallpaper
Use the Wallpaper profile configuration to apply a wallpaper image across all of your managed Android devices.
- Select Profiles from the main menu.
- Select a profile then click Edit.
- Select the Configurations tab, then Add. The Add a Configuration panel appears.
- Under Email and Others, select Wallpaper. The Wallpaper configuration panel appears.
- Select Set wallpaper on Home and Lock screen.
- Drag and drop an image on the screen or click Browse to locate an image file (.jpg or .png)
- To use a different image for the Lock screen, click the button and drag/drop an image onto the screen, or browse to an image file.
Note: This feature is supported on devices running Nougat or above. This restriction does not apply to Samsung ELM devices.
- Click Save. The wallpaper configuration is displayed on the selected profile.
- Click Save again to save the profile.
